rb25 & Spanish li150 engine case
carlos fandango
Yes that looks like one ;) But add in to the cost welding, skimming of the deck, machining of the spigot hole and drilling and tapping of the new studs :shock:
It is the later ones, I think with the neutral light ? has your one got that Eden?
carlos fandango
Have a look at this Caspa2006 [url]http://scooterotica.org/forum/viewtopic ... t=4260/url]
gaz_powell
i`ve got a mint indian gp150 casing and its is the same as the 200 other than spigot size, stud position and port size was going to get it converted to for TS1 225 barrel
JB Tuning quoted £90.00 +VAT last week - which I thought wasnt to bad
MBD have been doing this conversion to Spanish 150 blocks since 1985, Indian ones are much rarer. Since the availability of relatively cheap new Indian blocks the conversion went out of favor. NOW Indian blocks are getting harder and harder to get and the prices have doubled from the Indians it means this conversion is worth doing. Its well and truly perfected by now, Mark does each one start to finish MBD charge £95 +vat and each one can have the transfer ports opened to suit what ever cylinder is required.
Or like this!
Welded to suit Kawasaki KDX 200 cylinder
cs engineering in norwich has a batch of these to do next week ;)
