kickstart s/2
marburys
got sil engine for s/2 what kick start do i use any help please
Jet200
Series 1/2 kickstart pedal so it clears the wider footboards ;)
Mel K
Jet200 wrote:Series 1/2 kickstart pedal so it clears the wider footboards ;)
Won't you also need a series 2 side casing? Or extend the bit that rests on the rubber stop?
Yanker
Yes: extended by approx 50mm to reach the rubber stop: easy weld job, but better done on an old lever/b4 choromin' ;)
marburys
i got series 2 sidecasing with kickstart on. Can i just fit it on sil engine
jimmac
marburys wrote:i got series 2 sidecasing with kickstart on. Can i just fit it on sil engine
The chaincase side will fit, but remember that the SIL endplate is a different design (has the kick start ramp as part of the endplate, rather than part of the chaincase side).
Also, the S2 doesn't have the strengthening webs around the kickstart shaft, so you might find it will crack if you're using a larger capacity motor.
marburys
thanks for all your help take easy option and weld bit on kick start
Ian Hepworth
Easy option is to extend the part on the kickstart so it reaches the bump stop.
Harder option (with risk of crankcase side breaking where kickstart shaft goes in) use S1/2 crankcase side.
Harder option with more reliability - use a Spanish crankcase side where they are beefed up round the kickstart area.
marburys
cheers for your help
dirtyhandslopez
I have an odd casing here. A S3 casing without the extra enforcing ribs, looks like a S1/2 where the kickstart shaft is, but is definately S3 where the kickstarts bumb stop is. Anyone know what this is? Pre-pre-mod S3 perhaps?
That's not going anywhere...
    Users browsing this forum: No registered users and 77 guests
