DC Conversion again
Spud
I have just purchased one of the DC Battery rectifier from ScootRS (times are hard & i can't afford to upgrade my stator & go down the podtronics route).
I intend to add a battery in the not too distant, when i have a legshield toolbox fitted.
I would like to use a 12v DC supply for a Horn until i get some cash for the other jobs.
Now,i am sure i read somewhere that if there is no battery fitted, it is recommeded to add a Resistor.
Basically, can i connect the rectifier inline between the output from the regulator & the loom, to run the lights & the horn from DC?
Or should i leave the loom alone & run a wire from the rectifier to the horn?
Finally, when i do add a battery, would this setup give enough power to run the lights & do i need a fuse on the +ve side of the battery or the -ve side.
cheers
Spud
The set up you have opted for will be sufficient (just) to trickle charge a battery but it won't give enough DC power to power any lights or a horn directly as it will only give you half wave rectification. Having said that, a small battery will store up enough charge to operate a horn.
Spud wrote: (times are hard & i can't afford to upgrade my stator & go down the podtronics route).
cheers
Spud
Cost is about £25 plus a battery if you choose to fit one.
Spud
+ cost of fitting & painting legshield toolbox to hold the battery & doing the modification to the stator plate.
I was hoping to use this set up to have a horn that worked, until i can do the rest.
With your setup, does the battery feed all electrics via the loom, or just accessories?
Also which side is the fuse +ve or -ve
cheers
It doesn't cost anything to modify the stator, it's a diy job. I set one of mine up without a battery for the same reason as you, a decent horn and brighter more stable lighting and that's exactly what I got ;-)
It feeds all the electrics with or without the battery and is -ve earth.
firekdp
On a full DC conversion all the electrics are fed by the stator (up to it's max wattage), although there will be a small discharge from the battery to fill in the troughs of the rectified supply. So there will be a slight AC effect on the battery feed wire.
When the load is more than the stator max wattage the battery will come into use to maintain 12v.
Spud
So without a battery, you would connect the output from the podtronics to the loom.
Do you need to do anything else until a battery is fitted ?
when fitting a battery, is the fuse connected to the -ve or +ve.
cheers
Spud
Spud wrote:So without a battery, you would connect the output from the podtronics to the loom.
cheers
Spud
Yes
No
-ve
without a battery fitted, the horn will be better with the lights on.
which is probably not a problem, but something to remember at mot time
something to do with the rectifier unit not kicking out much until it is under load...
I'm sure firekdp could explain it better...
    Users browsing this forum: Google [Bot] and 7 guests
