MARK CHRISTIES KWAK 500 S6
frank sanderson
Mark has wants to finish the scoot himself so we have built to rolling chassis he has the new Bitubo front shocks fitted as used on SCOMADI good luck mate :wink:
[img]http://scoot.net/gallery/bbs/SSL11298.jpg[/img
Speed Demon
Are you going to tell him not to use that joke split-link chain Frank?
Get to SULK
Dryballs
frank sanderson wrote:Image
frank sanderson
clever lad sticky as you can see its in bare metal not finished chain is for set up purposes ;)
Its easier to work out a finished chain length with a split link type once you know your length you can do a rivetted one.
Speed Demon
Sorely it's only 2 Poundland tins of matt black away from completion - if you want to go mad on bling like.
Get to SULK
joespeed
so what is the engine out off? is it a 'crosser'
http://scooterotica.org/forum/viewtopic.php?f=7&t=4843
Here is a link to first part of the post. Thanks Frank, you have done a good job there mate. All I need to do now is get my ass up there to collect it. There will be no rattle cans for this bad boy :lol: It will have full carbon panel work and the rest maybe powder coated. I have all the parts to finish it at home, when I get home that is ha ha. Will post when things start comming together
wax
I assume you supplied the engine to frank? I was just wondering what it has cost you so far? I have a spare frame in the garage...............
frank sanderson
If you go to website www.lambrettainnovation.co.uk to the S6 sect you can download a kit cost /info sheet there are loads of other convs of this type there to see.
ta Frank
oldbiker
That has all the makings of a classic,
