speed woble
sion
Front end feels a bit wobley at speed a bit like a wheel out of balance any ideas
all looks ok
mb springs
servetta dampers
new bushes bearings ect
forks lovely and smooth
bit scary and ideas cheers
are you sure your frame is straight.......................?
davidblythe
loose steering head bearings :?:
davidblythe
if the wheel is out of balance you will see the front end shaking up and down as if riding over ripples in the road when it gets to its harmonic frequency
put your scoot on centre stand........with say two bricks underneath each leg..........
check for play in fork bearings.......
sion
frame checked by mike phenix on jig
bearings are spot on no lift not to tight
might try a different rim doestnt do it until about 9000 revs in 4th
might just have to live with it
what tyres you got on?
sion
oh its a spanish frame not indian and on dunlop tt92s
davidblythe
loose steering head bearings would come in at much lower speeds
out of balance wheels come in around 90 -110 mph on sports bikes and clear after that
sion
just had another look when you spin the front wheel it
does seem to raise up and down slightly when you spin it?
