Can anybody point me in the direction of said wiring diagram, post a link or mail me a picture ?
or is this the same, series 2 li with battery?
http://www.google.co.uk/imgres?imgurl=h ... CAcQ9QEwAA
cheers in advance
paul
Series 1 wiring diagram, battery model
There are several different types, here's one of them.
http://www.scooterhelp.com/electrics/pa ... ml#battery
cheers for the diagram
i am slightly confused now tho, electrics is not my strong suit but
looking at that diagram the rear light switch has 3 wires going to it on my bike it has 2 going to the pedal but i have the 3 festoon bulb type rear light,
so do i have the wrong switch? wiring or rear light set up for the electrics i have
cheers for any help
paul
cheers for any help
paul
Some models (even with a battery) were not fitted with brake lights from new, but have had them added later. Early models also used the blue stator wire to charge the battery, whereas on later ones the blue is unused and sheathed.
so last night i wired up a battery just to see what was working and the rear lights came on (1 either side) but the brake light wouldn't come on, all new bulbs fittedfirekdp wrote:Some models (even with a battery) were not fitted with brake lights from new, but have had them added later. Early models also used the blue stator wire to charge the battery, whereas on later ones the blue is unused and sheathed.
i have put a new brake switch on (as the pin was busted on the one already fitted) and this made no difference
is there anyway or anything i can check to see where the fault is?
sorry if i am sounding like a dummy
Firstly, the outer two lamps should be the brake lights, with the centre one being the tail light.
With the battery connected check that there is power to one side of the switch.
My S1 has the 3 pin brake light switch and the brake light works off the battery, so i would imagine the 3rd wire powers the switch up from the battery, so with only a 2 pin switch the engine will need to be running for your brake light to work.
that makes sense and i have traced the wire that powers the brakecraig69 wrote:My S1 has the 3 pin brake light switch and the brake light works off the battery, so i would imagine the 3rd wire powers the switch up from the battery, so with only a 2 pin switch the engine will need to be running for your brake light to work.
my next question is
on my bike the 2 wires going to the brake switch are both green, however one has copper wire inside it and the other has blackish
is that a problem or is it normal?
what colour should the wires be?
cheers
Measure it with an ohmmeter/contiuity tester as that wire is probably damaged. If the brake switch wires are green then it's more than likely the stop light is an addition.geepee wrote: that makes sense and i have traced the wire that powers the brake
my next question is
cheers
If the feed to it is from an AC circuit it would be beneficial to move it to a DC supply, as on a standard battery machine.
Re the horn in the wanted section, you need to specify whether you need AC or DC type, early series 1 machines (even with a battery) had an AC horn, later ones had DC .
If the wiring is looking a bit iffy like mine was i suggest getting a new loom made at Scooter Restorations, fantastic quality and all colour coded all for about £20 saved me a load of hassel :bouncyeng:
- Information
Who is online
Users browsing this forum: Ahrefs [Bot], Google [Bot], Semrush [Bot] and 9 guests
