Hints for clean cutting
sydduckett
Anyone got any hints for cutting braided metal fuel hose.want to try and get a nice even cut and avoid loads of frayed wire. was thinking of using the dremmel with a metal cutting wheel?
ta
sef
wezly
i've used a sharp pair of tin snips
oldbiker
wezly wrote:i've used a sharp pair of tin snips
SHARP yes that works a treat, or SHARP bolt cutters
sugarlump
Wrap some tape around the hose where you're cutting, helps to keep it from getting too messy. I've done it with a dremmel and cutting disc too, seemed ok.
joee
are we talking braided brake hose or fuel pipe hose?
I wrap a length of electrical tape around it then attach a hose clamp around the tape. Then I take a hack saw and cut it along the hose clamp. make sure you've got a fine tooth hacksaw blade 32tpi or a dremmel or cut off wheel will work..
make sure you blow the debris out of the hose after
randall ate my dog!!
no one likes us we dont care
i use things like this at work http://cgi.ebay.co.uk/VITREX-PLASTIC-PI ... 439c97d343
or garden secateurs
sydduckett
Cheers lads
