Anyone shed any light on this its doing me head in...
ta
sef
Wez, i have the splined end with the groove cut in. The grub screw on its own whether screwed into the splines or right down into the groove isnt strong eneough to stop the rod roataing in the wheel after 5 mins of riding. When i got the kit i thought i must have got the wrong one? Your suggestion of drilling and tapping sounds like the way to go, where did you drill through on the rod? Did you deepen the groove to get the bolt through or go through the middle of the groove and out the other side. I guess it doesnt matter apart from im worried that by the time iv drilled and tapped it will have weakened the rod. ideally rod without a groove would be the best bet then i could drill straight through the middle....wezly wrote:correct, the grub screw is for splined rods or use the two holes for a pin. although i drill and tap the rod and use M5 bolt rather than the pins as i find it easyer to get them in and out.
