BGM Stator and Agusto
Dazza
Anyone else have this setup aand encountered any problems?
I'm about to fit my BGM and had a sneaky feeling there was something I've read about doing so with an Agusto??
No problem at all, the issues were with CDIs, just use a Ducati unit and you'll be fine ;-)
wack 63
Main scooter: '71 GP TS1
Does the BGM stator work ok on a AF lightened flywheel(new type)? Don't want to buy one then find issues with the pick up height etc
Dazza wrote:Anyone else have this setup aand encountered any problems?
Have you got the agusto fitted Dazza..?, am gonna get one and was wondering what people thought, I know Red is well happy with his..
minotaur
got bgm , af lightened flywheel and agusto on 2 lammys with ducati cdi very happy...
Dazza
Yes mate - had it fitted for a while now, it seemed to make it pick up a lot cleaner from low revs - not a massive difference but noticeable.
Fitting the BGM for no other reason than the added reliability over the shitey indian coils I've had recently.
Got a Ducati CDI already fitted Mike - so hopefully that's ok - I had a niggling feeling there were other issues (apart from what Wack mentioned )
I take it you've done the same? Did you have to elongate the holes?
Dazza wrote:I take it you've done the same? Did you have to elongate the holes?
No, but IIRC it was on the limit ;)
Honeymonster
Dazza, got the BGM stator and Agusto on my curry burner, had no problems last year.
Ian
rossi46
had mine on for a year now, BGM, AF Flywheel no worries best £60 you can spend !! :mrgreen:
andylaw7
same here bgm stator agusto 7000 a f lightened flywheel apart from elongating the slots on stator and removing 2 laminates all okay so far thats with a ducatti also .,
