thought it would be a good idea opinions sought
davidblythe
thought I would try a pure copper gasket 3mm thick slightly extended to act as a heat sink
on the test one havent extended the sides like I intended too,
but they take more time than I thought they would mainly because I Need to make a better holding tool
also realised they need finishing by hand to suit the exhaust and pipe being used
then realised that I not really sure that it will work
opinions sought
one in picture still to be finished, got too cold in garage
DJB
Silicone :lol:
davidblythe
DJB wrote:Silicone :lol:
use silicone myself but was thinking along the heatsink side really
DJB
I would stick to a normal gasket. If its not broke?
soullad
David - give it a go, what you got to lose?
Also did you see the thread about using the cylinder cowl as a heat shrink. I.E. using the stud extending connectors / nuts on all 4 head studs and drilling thru 3 new holes in the cylinder cowl.
davidblythe
soullad wrote:David - give it a go, what you got to lose?
yes I did and am trying out another daft idea along those lines
mickdale
davidblythe wrote:yes I did and am trying out another daft idea along those lines
if you use the cowling as a heat sink you could weld fins to the cowling underside letting the airflow under the scoot draw heat off?
cezeta
my mate is using one of these mounted to his exhaust stub. its from a triumph. no idea if it works or not but food for thought.
rbgaz
please someone tell me what its for/do else i want be able to sleep tonight !!! :shock:
davidblythe
rbgaz wrote:please someone tell me what its for/do else i want be able to sleep tonight !!! :shock:
have a read of this ebay listing, very common on old brit iron
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 3D1&_rdc=1
