MB gear selector spring
giankx
Hi, i've just started to build my Ts1 and i've fitted an MB selector spring.
Will i have problems changing the gears? Will it be too stiff?
Ian Hepworth
You will have no problems if you use Nylon lined clutch and gear cables, routed with NO kinks or tight bends. Easy stuff!
lifes a drag
i had an uprated spring with nylon lined cables all correctly routed ,, could i change gear ? not very easily
gave my mate ago to make sure it wasnt me being a whimp ,,, same with him ,,
DJB
I had one, but not from MB and i couldnt even get it into the layshaft. Standard ones are fine(I think) There's alot of crap about : :cry:
giankx
Ok, but you refer all to the Mb spring or to other different ones?
I'll use nylon lined cables and hope to not have problems.
I Have bought these : http://www.scooterrestorations.com/lamb ... ree-black/
Will they up the job?
DJB
giankx wrote:Ok, but you refer all to the Mb spring or to other different ones?
You could always call on popeye :frog:
giankx
:lol: :lol:
cezeta
too stiff for me, ive never had a scooter jump out of gear either
surely the stronger springs do what they are supposed to do and that is to help prevent gears jumping out ,and to provide a better /more positive selection.
although they may seem somewhat difficult at first,time and use will tame these.... :D
    Users browsing this forum: Baidu [Spider] and 6 guests
