please help wont start!
DJB
Check the spark is not jumping to the side of the plug.
ridden not hidden wrote: i have spare regulator
the regulator is nothing to do with the ignition side of things.
But, as suggested, worth swapping out the CDI for a known good one.
dirtyhandslopez
Sounds like a woodruff key has taken a dump on you.
That's not going anywhere...
ridden not hidden
dirtyhandslopez wrote:Sounds like a woodruff key has taken a dump on you.
YOU ARE THE WINNER!!!! took flywheel off woodruff key not in situ must have got dislodged on assembly :oops: :oops: :oops: put it back together and first kick sweet as a nut
many thanks to everyone i am a happy bunny
glad you got it sorted ;)
cool 8-)
often the simplest of things...
dirtyhandslopez
Excellentness. I'm finally good for something :) Send the prize to: :biggrin:
    Users browsing this forum: Semrush [Bot] and 11 guests
