DAC -rear hub
caspa2006
hi all
anybody on here know any thing about DAC stuff, i want a rear disk setup on my
lammy project but dont really want to go the route of a out board disk, they look
bulky and they most be a pain if you get a flat, on my vespa project i am going
to use a left hand sip setup like the dac one.
can i use a dac rear hub and internal disk setup on a standard casing or do they
need to be modified in some way
DJB
You can run on a standard case with no mods what so ever
the dac disc doesnt require any mods to the case but you do end up with an 11 " wheel as the rim and hub are one peice
caspa2006
hi I no they are 11" but they use low profiles don't they so end up the same over all size
also are there tyre a higher speed rating or the same.
any body know the cost
DJB
I have a Dac rear hub, the tyre i use is a michelin pilot excellent tyre rated to 75mph. It has the same circumference as a 350x10.
caspa2006
cheers mate i thought they were the say dia. also do you know what was the rear rim off
the orange dac lammy in scootering the one with the 5 spoke hub/rim thing
the orange cutdown's rear wheel was a one off cnc'd hub based on a dragster front rim ,plenty of pics here...........
http://www.flickr.com/photos/anne-mark- ... 036665733/
caspa2006
great link cheers
    Users browsing this forum: No registered users and 21 guests
