New motor for spanish series 2
SKP
Hi guys, could do with some gearing advice for my next project. Have an overbored 66mm imola barrel and a 60mm crank thats going into my series 2, have both LI 150 & Pacemaker gearboxes. Which one is the best starting point and what final drive should I be aiming for ?
Thanks in advance SKP. :D
what use do you want it for , touring,racing ,2up ,what sort of bikes do you ride with or do you ride alone, what pipe and carb?
SKP
Hi Mark, should have put a little more detail in original post. Here goes, mainly ride without pillion and new scoot will be used for touring. Was intending to use 30mm Dellorto carb and either a 48mm clubman or if I can get one a MK4 Taffspeed. Any ideas ??
Thanks SKP
i would run a li 150 with 15/46 or 16/46 for a little more top end if it will pull it .
    Users browsing this forum: Semrush [Bot] and 10 guests
