18mm s/e 22mm b/e 116mm Yam rod
davidblythe
Finally found the Yamaha part no if anyone is interested
exactly the same rod as on my crank
6H4-11651-00
just got to find who sells them in the UK as opposed to the states
http://www.yamamotor.com.tw/product_vie ... 0801110013
http://liyang-china.com/product8.htm
chris2470
Why not ring these guys:
http://www.pjme.co.uk/acatalog/copy_of_ ... _End_.html
That should do the job, and cheap as chips.
Best Regards
davidblythe
chris2470 wrote:Why not ring these guys:
that has a 16mm s.end unfortunately
oldbiker
pjme are a good and helpfull dealer (well respected in yam circles) if you contact them and say what you need they will try to help you, even if it is boat stuff.
what is the width of that rod at the big end? I used to need to machine a little of some of the rods I used in the past.
Knowledge
David,
Is there not a con rod of this size sold by Harry Barlow? I am sure he has them this exact size in stock.
Martin
Martin
    Users browsing this forum: Semrush [Bot] and 16 guests
