disappointing DC conversion...
soulsurfer wrote:... run it and see how it works in practice ;)
the scooter is all back together as it was with just the wassell unit fitted, so probably a good idea to ride it about, that is the best test after all.
thanks for all your contributions
Try to get some sleep without thinking about it :lol:
Merry Christmas
firekdp
At what rev range were these voltage readings taken?
from tickover, revving it up a bit a few times until no increase in the readings. so not totally controlled, but i was doing this in my badly ventilated workshop with a bike that is running rich and ideally needs setting up, again by riding it...
I think i will see if the owner does want to blat it around a bit, at least til we get the rewound stator back...
firekdp
I would try and measure the voltage at a constant 3000rpm approx, if the volts are alright at this range I don't think you have a problem.
firekdp wrote:I would try and measure the voltage at a constant 3000rpm approx, if the volts are alright at this range I don't think you have a problem.
ok thanks again, so would be looking at around 14v at this rpm ?
Jarv, I agree with Soulsurfer, I don't think the size of the battery is the problem (if indeed there is a problem) my battery is a 7.2 Ah one. btw.
I have a bigger problem at the moment, we've jusrt drive 225 miles up to Wigan to do xmas with the inlaws and we've leftthere frikin present behind :oops: :oops:
Have a good one all ;)
coaster wrote:I have a bigger problem at the moment, we've jusrt drive 225 miles up to Wigan to do xmas with the inlaws and we've leftthere frikin present behind :oops: :oops:
:oops: oh dear. have a good one Colin
just tried it, about 3000 rpm, but only by ear, had a drink lunchtime so can't be arsed with hooking a tacho up....
measured at battery :
14.5v with lights off
around 12.5 with lights on
just over 12 with one pathfinder
11.5 with two
so does that seem ok ?
i did meet the owner for a beer earlier, he is going to ride it about a bit next week, so hopefully it will all be good....
don't you just love lambrettas :mrgreen:
Sounds okay to me ;) ....................NOW LEAVE IT AND GO HAVE A VERY MERRY CHRISTMAS!!! :D
soulsurfer wrote:Sounds okay to me ;) ....................NOW LEAVE IT AND GO HAVE A VERY MERRY CHRISTMAS!!! :D
Ditto, that's pretty much the same as mine 8-)
Pressie sorted now :roll:
    Users browsing this forum: Semrush [Bot] and 8 guests
