schwalbe power track tyres
No such luck there its Indian..should be able to file with a toothbrush.. :?
mouse
Lam46 wrote:No such luck there its Indian..should be able to file with a toothbrush.. :?
do yo want some big bags of italian filings we have loads here and they are very cheap, couple of pints of johns should do it :biggrin: :biggrin:
DJB
soulsurfer wrote:
Lam46 wrote:I know with mine which I run wide rim 100/90 on the rear it has clearance from the engine case even sat on it theres a gap...
If you sit on it, surely the tyre will bulge at the bottom, not at the side where it'd rub the casing :?
mouse wrote:For those of you who think the tyre will bulge only at the
bottom are wrong. Imagine at speed under compression the tyre will
deform and send that bulge around the whole tyre.......
But not if you're stationary ;)
mouse
we dont sell stationary, only top quality scooter parts :biggrin:
mouse wrote:we dont sell stationary, only top quality scooter parts
You need paul green for that.. :frog: ..I might some of those metal fillings for me head..just to fill in the gaps.. :lol:
That's quite a chunk taken out :shock: How thick are the casings there, I would think that's a weak point, on that engine at least?
DJB
The other side. No problems what so ever.
http://www.flickr.com/photos/anne-mark- ... otostream/
al-super3
mouse wrote:we don't advise using 100/90 tyres on wide rims, you can use a 3.50 on a wide rim or a 100/90 on a standard rim but you should be very careful using 100/90 on wide rims, remember the tyre expands when it gets warm!
Thanks for this i had a look this morning there is a faint polished line on the engine case and a small mark on the tyre where the clutch arm is, so after xmas i will have a go at spaceing it if that dont work 3.50/10 it is ;)
merry xmas Al
Scream at me until my ears bleed
    Users browsing this forum: Google [Bot] and 16 guests
