Ts 1 225 Carb
roadrunnerian
Hi what carb should i put on my lammy ts 1 225 at the moment i am running an 34mm amal but every one says to use the mikuni any suggestions welcome thanks ian
DJB
If your Amal is set up i would leave it. If not a 35 tmx.
whats wrong with the amal ...?
roadrunnerian
nothing is wrong with my amal it has about 400 hundred miles only on it i have been told to put a different carb because the amal is hard to set and the mikuni 35 mm is a lot better and easy to set up and gives more miles to the gallon.
DJB
roadrunnerian wrote:nothing is wrong with my amal it has about 400 hundred miles only on it i have been told to put a different carb because the amal is hard to set and the mikuni 35 mm is a lot better and easy to set up and gives more miles to the gallon.
If you do change try these.
http://www.allensperformance.co.uk/prod ... bkits.html
Very good service and dont charge the earth like scooter dealers.
There's a reason for that ;)
Train Driver
I am using a 24mm mikuni on my 225 classic rapido and get about 55 mpg, i intend using the same carb on my RT260 kit, have discussed it with mark who said it will run fine
TS1-200
Mikuni`s are definitely a bit easier to set -up, but an Amal or Dellorto can be set up more accurately with a bit more effort. in my experience.
Keep on keepin on
