can anyone help or give me advice on this problem
lambro63
Main scooter: series 2 TS1
i wish to set up a tomtom rider 2 on my lambretta
the advice i need is.....
a/ how would you mount it on a series 2 headset
b/ could it be run off a normal stator or would i need a varitronic set up to run this sat nav
so can anyone help me with the mounting of this unit & powering of it any photos or ideas would be great thankyou
regards
big pete lambro63 (spiderman)
i think it will only run a a dc battery system and some sort of bracket on the right hand site throttle/light switch mount as they have holes in them already that you can use
Knowledge
Yes, you will need a 12V DC supply, although the battery in the Tom Tom should give several hours of use.
Have you a spare wheel at the front? You could build a simple bracket off either the spare wheel holder, or one of the holes in the spare wheel itself.
Martin
