can someone please explain dwell
was told to set a mates engine up with 30 degree dwell. what is it?
firekdp
It's the number of degrees that the points must remain closed to allow the flux to build up to a sufficient level in the HT coil in a battery powered ignition system.
so it dont matter in an electronic system
firekdp
Correct, it doesn't matter.
hungdog
Yeah it's quite easy really, wait for it.....................
:frog:
dsc scotty
Or are you talking dwell period? the amount of time/degrees the inlet port is clear of piston? as you stated 30 degrees I suspect that may be what you mean?
this also crossed my mind when i saw this post,
dwell in terms of inlet timing is the amount of time that a port is fully open and unobstructed,
Daggs
I thought the 'dwell' is where the 'dwater' came from!
Sorry, i've been on the ale........... :bouncyeng:
that sounds more like it sean thanks :( :lol:
    Users browsing this forum: Semrush [Bot] and 12 guests
