Whats this RB barrel?
carlos fandango
Picked this barrel up recently, and im a bit puzzled as to what it is. :?
Is is unused, RB225 ports, but is 72mm bore, the spigot is 78mm and not stepped like the rb250s so very close to the stud holes :o
The spigot is as cast not welded or anything?
so what do you reckon?
odd mod squad
hello there
you will find its a very early one :)
if i remember correctly jb tunning used to machine and step the barrels and mod the piston
has anyone got a 250 new or old
and any feed back on their pros and cons
happy days 8-)
eibargum
Looking at the inlet it looks like a RB22 as the only 25s ive seen have had two fingers in the inlet to support the rings, unless like odd mod says its a early one and they changed them, if its got a number on you could ring Kempy up as they keep records ;) .
carlos fandango
Well it is an early one number 27
RobD
If it's an early one then I believe the port timings will be for a 58mm stroke crank. I've got one the same and had the barrel top and tailed for 58mm stroke. A bored out RB22 effectively. Alternatively could machine to suit 60mm stroke as taffspeed did.
    Users browsing this forum: No registered users and 68 guests
