The next nust-have gadget?
ArmandTanzarian
It now seems that many many owners of tuned Lambrettas won't leave home without an EGT. Could this be the next must-have gadget?
http://cgi.ebay.co.uk/LAMBRETTA-AIR-FUE ... 518e797832
wax
I have just ordered one of these for my RB engine. The EGT's are ok, but don't tell you what the problem is, only that you have a problem, if the temp suddenly shoots up. At least with this you can see if your mixture has gone pete tongue, due to an airleak / fuel starvation etc. I am not too sure these senders will live too long though, having read the blerb that came with the kit. The 2 stroke oil could well clog em up. Only time will tell. John at JB told me that you have to be sure that the sealant on the head / gaskets is the right type, as some coat the sender up with contaminates: something he experienced on his dyno. I will keep you posted, when i get it up and running though. However, i am having a full paint job so it might not be til spring..... 8-)
caspa2006
soosh
Soon we will have the mrs sitting in the living room with the laptop starting the engine for us.
cezeta
two bored minds think alike
http://scooterotica.org/tempforum/viewt ... f=7&t=6643" onclick="window.open(this.href);return false;
carlos fandango
I was looking at one of these a while back until i read the instruction manual. Re. petrol/ oil mix
"The oxygen sensor in your K&N Air/Fuel Monitor assembly is not compatible with leaded fuels or any fuel additive containing lead. Leaded fuel will contaminate the oxygen sensor causing it to deliver a false reading. The Monitor can, however, be used to momentarily test an engine burning leaded fuel. Simply install the sensor - re-calibrate the fuel delivery system to deliver the desired air/fuel ratio - then remove the sensor to avoid prolonged exposure. This short term exposure will extend the useful life of the sensor when testing an engine burning leaded fuel, but eventually it will become contaminated. Once contaminated, the sensor must be replaced to restore the accuracy of your instrument. Additionally, since there is no efficient way to test the sensor, there is no way to determine the level of contamination. Therefore, we recommend periodically comparing a used sensor to a new one.
Other products that will contaminate or clog the sensor are:
• Gas/oil mixture • Injector or carburetor cleaners contain lead additives
• Octane boosters containing lead • Other “secret potions”.
carlos fandango
Oh and you can get them cheaper off the t`internet than Mr Wilkins wants for it on ebay ;)
wax
Secret potions? Sounds interesting..........
