a strange 200 barrel what is it
odd mod squad
hello all
i need help :?: a 200 barrel of a tv 200 but with a 175 inlet :P
the quetion is
is the barrel of a lambo or something different
any ideas :idea:
dirtyhandslopez
Ian Hepworth wrote:Lambro.
Any good for doing anything with? I have at least one.
That's not going anywhere...
Ian Hepworth
The ports are all over the place. The inlet port points the wrong way.
Perhaps useful as the basis for a reed valve conversion where you will be doing some porting work as well but not a lot of use as a standard cylinder.
dirtyhandslopez
Thank you kindly. Had only noticed the size of the inlet (or lack of it) not which way it pointed.
soosh
Had one once and the spigot was machined down to fit a 125/150 casing about 10yrs ago and fitted it to a mates LI150 with no silent blocks. You could feel the vibration going all up ya arms via the headset,it was horrible.It pulled like fook but wouldnt rev,it would pull tall gearing though.Im sure its a doorstop now.
    Users browsing this forum: Amazon [Bot] and 6 guests
