Does anyone know from what model vega or vespa the long 7mm barrel nuts come from
want to use them on a TS1 Exhaust studs for ease of tightening and lock wiring
7mm barrell nuts
davidblythe
davidblythe
many thanks gnasher
sip sell em for 20 quid each or something.
I use em on smallie heads. Mk1 t5 had em on the engine cowl cover near gearbox selector
davidblythe
tony wrote:sip sell em for 20 quid each or something.I use em on smallie heads. Mk1 t5 had em on the engine cowl cover near gearbox selector
will try SGT,s tomorrow
david buy some hexagon bar from here and make your own 7mm long nuts http://www.chronos.ltd.uk/acatalog/Chro ... A_283.html
cheers ralph
cheers ralph
- corrado
- Dealer
- Main scooter: Lambretta GP
I've got a pair of these but now I know what to use them fordavidblythe wrote:Does anyone know from what model vega or vespa the long 7mm barrel nuts come from
http://www.sip-scootershop.com/Products ... wl+M7.aspx
Or what about drilling/tap to m8 and use k nuts.
i always use one normal 7mm nut (steel) under hard to get at bit and a 7mm allen bolt on easy to get at bit of downpipe then locwire each together . surely a longer nut would be even wqorse to tighten up
