lights / horn
dunno if theres enough room under a lammy horncast but iv fitted these to my last 2 gts,s and my lml there about twice as loud as a mormal one http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0403583973
al-super3
dapper wrote:I've got a Yuasa NP 1-2-12 12Volt 1.2 Ah, about the size of a fag packet mounted in my toolbox. LED rear lamp, normal headlight lamp, all bright as feck. Horn and brake light work even with engine off
Thanks for that will have a play :D
Scream at me until my ears bleed
dapper
byron wrote:
dapper wrote: 1.2 Ah
it's good you only need that rating, keeps the physical size small. i was surprised to learn the other day that oe batteries were something like 11Ah! what wattage are your headlamp bulbs ?
Feck me, that's enough to turn an engine over, if you had electric start :o :shock: As I said I've got LED rear combined lamp, no festoon lamp and standard headlamp/speedo lamp and have used one of those Halogens without the proper dipping bit. All bright as feck (obviously lamps are dimmer when ticking over)
    Users browsing this forum: Amazon [Bot], Google [Bot] and 8 guests
