front damper /gator options
ok a friend needs some front dampers and would like the stiffer "fat" ones but he also wants gators does anyone know who does "fat" gators is there such a thing :?
bristolmod
I've managed to put some standard gaitors on "fat" front dampers.
They're about £9 on Ebay.
Simply cut off the inner "lip" top and bottom with a scalpal, and chuck them in a bowl of boiling water.
Its an effort, but you will be able to get them on the dampers with a bit of effort (remove dampers from forks for ease of use)
Scootering since 1968.
cheers chris
mawso
bristolmod wrote:I've managed to put some standard gaitors on "fat" front dampers.
Hi Chris
Could you take a photo and post up of these pls?
Have 2 pairs of dampers at the moment, neither correct...too thin & too fat.
Fat ones are Armstrong Indian, what make are yours?
Stu
bristolmod
As requested- the gaitors are so tight on the damper that I can't slide them off!! The dampers are chrome and have "AF" stamped on them- if you want me to measure the diameter at the top please shout.
rakki
Main scooter: sx|px|rally×2
I have fat Indian dampers and set of BSA Bantam gaitors from eBay for them. Fit is okay without cutting, but I did put jubilee clips to top (don't know if they're necessary).
tom-wsp
+1 use BSA one's probably got a set in the shop if you wanna pick em up tomorrow mate
They look spot on to me.
mawso
Thanks Chris
bristolmod wrote:if you want me to measure the diameter at the top please shout.
If you wouldn't mind, I'd appreciate it. Want to see how they compare to the Armstrongs. Thanks.
Rakki, they look a very good fit, thanks for the info.
tom-wsp wrote:+1 use BSA one's probably got a set in the shop if you wanna pick em up tomorrow mate
Tom, how much are they a pair pls?
Thanks all.
Stu
tom-wsp
£10 posted to forum members
    Users browsing this forum: Ahrefs [Bot] and 6 guests
