cam lam adj power jet
Any chance you could post the instructions Gaz? ;)
rbgaz
hi mate all the fitting inst just tell u how to drill the holes for jet and supply fron bottom of float bowl thats it lol dosnt go in to detail how it works etc
What, nothing on how to set it up? Typical :twisted:
rbgaz
lol not unless they forgot to put that info in
Do you have to cut the tube, as I thought they were adjustable and assumed the tube could be adjusted to move in and out depending on conditions and use required?
How long is the tube?
rbgaz
when they say adjustable its for opening and closeing the jet to let more or less petrol in the jet it self can be cut to were u want it to sit in the carb mouth
Hmmm, sounds like it's best set up by someone that knows what they're doing and probably with a dyno :?
Has anyone out there already fitted one of these???
