Which clutch pressure plate? LI 125 s3
dansuper
Main scooter: 1963 LI 185
Just realised my original clutch pressure plate/basket has the long locating spindle, so doesn't fit my Indian GP 200 gear box (it's not drilled).
I thought a replacement plate without the spindle would be the solution, but Sticky claims this is the 'worst' set up. Anyone else have an opinion on this?
I'm rebuilding the engine with the Casa 185 cylinder kit, so I don't think the clutch will be particularly traumatised.
And - sacrilege, I know - could you grind off the locating spindle from the original plate?
Thanks,
Dan
yes u can grind the spindle iv done it lots of times
bristolmod
The spindle type is the better option, but it does mean finding a drilled Xmas tree to match.
I've done the same as Shocky with no noticable difference
Scootering since 1968.
Just make sure the remaining stub doesn't bottom out on the top of the Xmas tree. Otherwise use a Winco one from AF and just grind off the SX type nipple as they don't come in a GP type.
dansuper
Thanks everyone - looks like I may go down the grinding path.
Cheers,
Dan
rog60
Main scooter: Indian GP200
before you do............... I've built a Casa 185 using a late SX engine (no stub at rear of pressure plate)........no problems.
    Users browsing this forum: Ahrefs [Bot] and 32 guests
