Front Dampers
Spud
Has anyone used any other makes of front dampers apart from the kawasaki ones.
Are there any Gas/adjustable ones on the market that will fit a lammy?
GPMatt
I've got BGM Fronts on two of my scooters and they are superb! the best standard looking ones imo are the AF ones but BGM are adjustable are definitely a step i the right direction.
GPMatt
You can get them from MB Developments or JB Tuning's online shop and you'll have them next day!
CPH Lambretta
Main scooter: DL 150 1970
Scooter Center have started doing the BGM dampers in chrome now as well.
Slow is the new fast!
Spud wrote:Has anyone used any other makes of front dampers apart from the kawasaki ones.
theres plenty just depends if you wanna modify your forks or links i used an external conversion from frank sanderson on my gp ,the extra width that these have gives better road holding i found them great with a scootrs disc infact i have a second one that i no longer need as i have sold my scooters
if your gonna have stiffer dampers be carefull that there not to stiff as they can damage the mounting points or even rip them off as the standard ones are only 6mm, serveta fitted heavy duty dampers to the later 200 range these have 9mm mountings for that very reason and the external conversion uses 12mm
Have a look at the Spax mini ones...
http://scooterotica.org/tempforum/viewt ... 3&start=10
    Users browsing this forum: No registered users and 21 guests
