ts1 dyno graph
Adspeed
drew2 wrote:yes,i would be interested ;) ,with an agusto but cant make
my mind up on which one is best,are you running one,if
so what type.
Stop guessin and get a http://scooterotica.org/tempforum/viewt ... 26&start=0
More graphs & specs please!! :D :D 8-) 8-) :D :D
yam-lam
Main scooter: serveta 125li & t5
drew2 wrote:yes,i would be interested ;) ,was going to pop to diablo
myself to get mine set up with an agusto but cant make
so what type.
not running an augusto box on mine, but my friend is thinking off getting one on his 240 monza soon which he will be taking to al's to be set up
yam-lam
this is my other mb ts1 slightly different from the other one
mb ts1 225 race tune,forged piston 70mm,ceramic lining, v force reed block, mb race tune porting, high comp cylinder head (only slightly more compression than the standard mb ts1 head )
58mm black italian crank (not h.p.c )
no porting to transfer feeds on engine case
standard indian electronic 17 degrees standard weight flywheel
five plate surflex clutch with mb springs and crown wheel
indian gp 200 gear box 19x46 sprockets = 4.8
35 mikuni
this engine is a work in progress, im happy the way the engine is at the moment , but there is always room for change to the engine. each change to the engine gets dyno tested to see if there is any benefit or not.... next item is a full circle 58mm crank then dyno test then a lightened flywheel and dyno tested then port casing and so on :D :D
just over to drop the scoot over to chris tonight .... fingers crossed may have a new crank in for morecambe :biggrin: :biggrin
yam-lam
forgot to post results , not easy to read on graph
26.3hp @6909rpm/ 21ft-lbs@6539
lambro63
Main scooter: series 2 TS1
yam lam do you have chris sturgress tel phone number please those results from a ts1 are very interesting i would like some thing similar
regards peter
regards
big pete lambro63 (spiderman)
yam-lam
lambro63 wrote:yam lam do you have chris sturgress tel phone number please those results from a ts1 are very interesting i would like some thing similar
regards peter
hi pete his number is 07791220193 , he is also (chris cspe) on this site , hope this helps
Diablo
6LDA 28B wrote:Again for the dyno/tuning experts 27.4hp @7396rpm 20ft-lbs@7076rpm how could he get the same power and torque at 1300 rpm less.
Possibly a little less power but maybe more torque could be achieved with less exhaust timing which would bring peak power down. maybe not below 6000 rpm but around about there.
I have 240s that make 25.5hp and 22/23ft-lbs. The same would be achievable with these motors I think.
Chris dynos all his bikes at my place and the test ride is always something I look forward to because they ride like new bikes. The guys work is outstanding.
