which engine should I go for.
Lui
Let me suggest the following:
Monza 240
62mm Tino Sacchi Long stroke crank
17/46 sprockets
stage 6 porting
35mm Mikuni Carb
PM 28 Exhaust
AF Lightened Flywheel
Electronic Ignition
Carbon Fiber Reeds, Polini carbon fiber with the bridge cut on the cage for one reed per side
very fast without compromising the reliability
Guillermo
4417 Glacier Street Unit C
San Diego, CA 92120
Business Hours (PST): 9am-5pm Tuesday-Friday, 10am-3pm Saturday - Closed Sunday & Monday
619-528-1677 - Orders
619-528-1678 - Tech Support
877-WCLW-ROCKS - Toll-free in the US
619-528-1679 - 24 hour fax number
stew
Main scooter: Series 1 and series 2
caspa2006 wrote:ok i am going to order me an engine this month were is the best place to order one from
i have emailed readspeed and fox to get a price on a 250/260 rb, do not have a limited budget
so i want some thing that goes the game
There are probably others that will do a good job. Though I would recommend Andy Francis.
Loud pipes save lives!!
caspa2006
how much are we talking for a complete new engine only a rough guide
2500 - 3000, or would it be better to get a complete old engine and send it
off to be done. i know were there is a tv200 for about 650 quid
http://cgi.ebay.co.uk/LAMBRETTA-TV-200c ... 20adf03361 is it worth
getting this and send it off to be rb'd, or what are the best casing to use
Jet200
If you're not on a limited budget have you had a look at the Targa Twin from CamLam? £8,500 and then all you do is bolt it into your frame! :D
hungdog
Or go for the DAC 320... :mrgreen:
bazman
http://www.andyfrancisscooters.co.uk/
Check out the ts1 250 on the shop online section ( other engines as well ) :)
lamy150
slightly tweaked monza 240,v-force,alpha full cicle,lightened flywheel,
6 plate clutch,sx200 gearing,tmx35,mb piston,floats my boat ;) ,fastest
scooter i've been on,mind you i would say that :D ,thing is,is to ask
about and buy the best you can.
carlos fandango
Hi Del
Was hoping to see you tonight.
Have a look at the "ts1 dyno" thread, yam-lam (mat) is one of my mates from over walsall. and chris is a top engine builder ;) . Give him a ring (he`s in aldridge) and he`ll sort you out. ( dont think he likes RBs though)
Russ
tony
Main scooter: 90ss
Jet200 wrote:If you're not on a limited budget have you had a look at the Targa Twin from CamLam? £8,500 and then all you do is bolt it into your frame! :D
and then take it back to charlie for a race spec tune :twisted:
adriang
Drop an RD350 lump into the frame??
    Users browsing this forum: Ahrefs [Bot], Google [Bot] and 11 guests
