Lambretta disc set up with typhoon
Someone was telling me yesterday at brid about his hydraulic set up with standard handle bar and cable..anyone else done this and have pics..apparently he used the rear set up of a typhoon rev and go and it fits behind the horncast..? I know you can get the hidden masters for there just would like to see a typhoon set up..
Cheers Andy.
Mel K
I think Frank Sanderson does them and has posted pics up, check out his postings.
tony
Main scooter: 90ss
One's I've fitted are the front typhoon ones. Work well. Got one on my racer. It will fit under the horncast with a small reservoir too. You'll need brackets welded on to the frame to mount it all.https://beedspeed.com/product_info.php/ ... ts_id/6177
That be the one Tony cheers..He had his mounted to the horn bracket..my eldest son works in a scrap yard and they get loads of rev and goes usally stolen and recovered..better have a word with him me thinks.. :)
Lamaddict
I fitted mine into the horn area and still managed to get the horn on but it was tight. I was using a Scootrs brake and it helped make the brake work really well without grabbing/locking too much.
    Users browsing this forum: Ahrefs [Bot], Google [Bot] and 5 guests
