advice on air saw blades
davidblythe
Need to buy an air saw, any tips
re replacement blades are they common to most saws like a 4.5 inch angle grinding blade is to all angle grinders or are the blades specific
and can you modify junior hacksaw blade to fit in an emergency
ta in advance
oldbiker
I`ve never found an airsaw that was any use I`m sure that there must be at least one good make but I have not found it yet.
any decent bimetalic blade can be cut down to size and are just as good as those that come supplied with the saws
I have had my air saw since 1990,and its still great.
Its a "spottle" NILE AF 10,and it uses the 12" type hacksaw blades..but cut into 4" lengths.
I prefer the snap on HSBM blades.
for panel work with intricate curves i just use an electric "jig saw" type .
oldbiker
http://www.muromoto.co.jp/english/conte ... f/en18.pdf
Looks good to me, the rest of the stuff looks well made
