best way to cut 13mm hex bar
davidblythe
Using an angle grinder to date, a bit brutal and too lazy to use a hacksaw blade
what better ways are there to cut up to half inch hex bar
monkey boy
Hi David
If you have space source yourself one of these on the cheap.
Should be a glut of them about at the mo
http://cgi.ebay.co.uk/Mec-Brown-75-Cut- ... 3356efeda1
leigh
Invite a mate round get them to cut with saw whilst you pretend to do something else.
Leigh
oldbiker
it can easily be cut in a lathe with a parting tool,
capstan and turret lathes are made for that sort of thing (production batches) but a standard sliding surfacing and screwcutting lathe (sss lathe) like yours should be ok as long as you are not cutting long pieces
davidblythe
thats the rub steve, One metre lengths at a time cutting off in 35mm intervals
oldbiker
put the steel down the spout of the lathe,
and use a support to stop the length sticking out from the back of the headstock from flapping about and bending,
lock the tool post in position,
lock the tailstock in position and use that as a guide to obtain the lengths that you are cutting,
use a parting tool to cut off the 35mm pieces,
otherwise use leighs idea
    Users browsing this forum: Google [Bot] and 12 guests
