What cc ???
Train Driver
62mm crank with a 115 rod using a 71 mm piston what will be the cc,
I am still not sure if i shoud go with a Mb RT kit or stay with my classic rapido 225.
I will be getting the crank whatever
Stokie
If you're considering the RT because of the tuning then why not send your Rapido to MB (or someone else) to have it tuned to a similar spec ?
I'd have thought it'd be the less costly option.
Train Driver
Well happy with the rapido so will most likely stay with it, the engine is going up to chalky at replay who has a 63mm crank
it was chalky who tried to explain about con rod length (115/116 better)
Staying with the 24mm mikuni and ancillotti clubman
