Crank Play
Should you be able to feel any play in the crank?
If I hold the flywheel I can feel a slight up/down/left/right movement. Just wondering if this is normal :?
jonny snatchsniffer
should be very minimal, even with c3 bearings, i had about half a mm play side to side and after 70 miles had 5mm still done another 70 miles with it screaming like a stone was in the fins rubbing on the cowl, but that was cos i did a dry build and forgot to repack the flange with grease :oops:
