Hi ,got around 200 miles on it last week ,haven't been on it since sunday ,the front shockers are realy hard ,even on the bottom setting they hardly move,so hoping they will bed in a bit (even with my weight).The front brakes another story ,can't seem to bleed the air out properly ,its come to a bit with using it,going to try and bleed it again at the weekend and if it's no better i have another master cylinder to try but it will need the mounting swaping as well.Also waiting for the speedo wire extension to arrive, as i'm going to run it off the rear hub as theres to much going on at the front end.Lam46 wrote:Hows the running in going, so whats the front end like under braking can only imaging its top notch
