In anticipation of receiving a JL curly pipe to fit to my Li150 Series 2 I have been thinking about carbs and jetting. Engine is a standard Li 150.
Everything I read about the JL curly says "get more fuel in or it's running too lean".
With that in mind I've thought about fitting an SH1/20 carb which I have spare from a previous engine rebuild. It seems much easier to get components for this carb than for the original MA18 currently fitted.
The SH1/20 is from an SX150 and is jetted as follows :-
Main 105
Choke 50
Atomiser F899-5
Pilot 45
A couple of questions :-
1. I understand the atomiser is supplying all the petrol from 3/4 throttle on up. Is the F899-5 big enough? Is see there is even a F899-6 available at Cam Lam.
2. Do you think the main is big enough?
3. Will I get it right with simple trial and error?
Best regards
Ben
