Using a 60mm (or bigger) crank
ArmandTanzarian
This is probably a stupid question but....
Apart from a packing plate, what other work is required to get a longer stroke setup working and how much is it likely to cost.
Knowledge
Crankcase-wise, up to 60mm, you might have to do some work altering the back of the inside of the crank case to allow the big end to rotate. Above 62mm you will definately expect to have to mod the inside of the crankcase.
Martin
