killing plugs
- jackpot
anyone any ideas why i keep killing spark plugs,and not just one make of plug,2 last week and 1 today after about 25 miles.they're still sparking but with about 3 sparks going back into the plug and not jumping the gap,HELP PLEASE
ON MY SCOOT OR NOT AT ALL
possibly detonation, and its cracking the porcelain insulator.
- jackpot
should cracks be visible ?,plugs look mint.it's running rich on the bottom end but surely that can't cause it[it goes back up to dans next sat] at this rate i'll need 3 or 4 plugs to get thereJ1MS wrote:possibly detonation, and its cracking the porcelain insulator.
No there not normally visible unless the insulator shatters at some point, my guess is if its just a little bit of detonation & the scooter is possibly a little rich. Then the plug tracks to earth inside the insulator giving a very insufficient spark at the tip till it doesn't spark except through the insulator, then it cuts out or just fails to kick up after you stop.jackpot wrote:should cracks be visible ?,plugs look mint.it's running rich on the bottom end but surely that can't cause it[it goes back up to dans next sat] at this rate i'll need 3 or 4 plugs to get thereJ1MS wrote:possibly detonation, and its cracking the porcelain insulator.
This really is only a guess and I'm not even sure its whats wrong with yours, just a possibility... I'm sure Dan will put it right, whatever the problem is...
- sean brady scooters
- Dealer
wrong grade plugs,thats all.
- jackpot
ngk 8,ngk9,nippon denso forget the number without going in garage but the correct equivalent,they can't all be wrong ?sean brady scooters wrote:wrong grade plugs,thats all.
- Andy Pickering
- Main scooter: GP
Would it be something like faulty CDI, faulty stator sending to much power as in a surge and the weakest link being the plug..bit like a light bulb blowing after power surge..?
You could try gaping the plug down to a very small gap, about 12 thou and see if it helps, if it does then its possibly a weak spark, Dan is possibly right, maybe wrong plug grade might be the problem.
But as I said, I am only guessing, and I'm probably miles off with my guesses...
- red
- Main scooter: Scomadi TL 250 (Ltd Ed No.3)
3 vapor speedos ,then 3 spark plugs!!
What's next?
Not cranks as you've already done more than 3
What's next?
- Information
Who is online
Users browsing this forum: Google [Bot], Majestic-12 [Bot], Semrush [Bot] and 21 guests
