GP FLYWHEEL BEARING FAG
sydduckett
Need to get a new mag side bearing, are the fag ones the best ones to go for. The current one on inspection wobbles about all over the place and has got some grinding going on when moved.... :evil:
Cheapest i have found is £28, anywhere cheaper or is there an upgrade thats worth buying. also is there a new seal out that replaces the L shaped steel washer when fitting the bearing?
Ta
sef
Bilko
Main scooter: LI150
Try Corrado on here. I got my bearings from him.
Bilko's Oily Blog
sydduckett
How do you pm someone on here when there not on yer thread....im a dunce...
lammydave
Bilko
Main scooter: LI150
Just type his name in the search option at the top
Bilko's Oily Blog
J1MS
If you cant get one at a decent price, try doing what I did. Find a couple of other people interested in placing an order for these bearings, buying a few at a time cuts the price... This way mine cost me about £15 each FAG NU2205E C3 bearings...
Just ring a few bearing stockists and get a decent price, then ask a few members at your local scooter club if they want to split the cost with you. There's always a lambretta engine getting new bearings fitted, so you cant be the only one...
