Front Dampers
Doom Patrol wrote:...Besides which I seem to think that the mounting brackets for the Spanish dampers are different and may not fit a conventional set up.
yeah, the Spanish ones have larger [9mm?] holes, and the fork bracket is the stud, rather than the two clamps, if you get what I mean, i didn't explain that very well...
Indian ones for me, avoid the shiny ebay ones with garden hose for bushes :roll:
tony
Main scooter: 90ss
I think most grp4 racers use fancy dampers like the bitubos. Have a look at the race pics I've posted to see what they are using fellas.
Mr Ed
Tanks for all your feedback people. Appreciate it. 8-)
Soulpunk
TIP:
use mini front dampers on 9mm serveta forks / links.
adjustable, good quality / vfm.
Mr Ed
Are these the escort ones. It's not very clear.
Soulpunk wrote:TIP:
They look good.
What about cutting the black bit off, turning upside down and making some 8mm top hats?? :idea:
Where can you get them from and what do you ask for?
Do they damp only one way and if so, on compression or rebound?
EDIT: http://www.minisport.com/acatalog/Red_G ... _Mini.html
Are they the correct length?
Nic
soulsurfer wrote:
They look good.
Also very interested: there appear to be different lengths....
They are matey, LCGB superdealer so not your normal e-bay trash, just good ol donny lad. :D
Soulpunk
they are dampening both ways. like sebac shocks or escorts or riv ones.
for the length,...too lazy to go in the garage or visit a mates mini-shed...
will post in few days..
the dampers are top. the quality is good. and they also look ok (on a late jet / lince / gp-racer) compared to the door-opener hydraulics / "alloutside" suzuki-chrome-kits on the market.
there are other manufacturers also like gaz, etc..
just check the mini shops.
Those Mini dampers do look interesting, don't they?
