is a 150 head coling smaller than a 200
cezeta
is a 150 head coling smaller than a 200 as im trying to fit a remade one and its too small, the original does fit though :?
a series 1 one is 7mm shorter but same size otherwise. that is the only difference
156 D
.....If you look at the 9th item down you will see a new part No. for the GT200 cowling.....so this particular one must be different to the other series 3 cowls.......
.....Image
Nostalgia is a thing of the past!....
think that one has a scoop . there is no difference in size
bristolmod
yes- the only difference in S2 and S3's cowls is the scoop- some had and some didn't. As stated above, the S1 cowl was shorter.
As yours is a remade item, I would imagine its made incorrectly (yes I know this is hard to believe...... :D )
My list of "GT200" parts certainly gets about!!!
Chris
Scootering since 1968.
    Users browsing this forum: Ahrefs [Bot] and 10 guests
