Lightened Rear Sprocket
dapper
- registered user
- Main scooter: The Biriani Bullet
- Contact:
Any benefits? Thought I saw a thread on this but cannot find it so sorry to post again. Less inertia?? Less strain on chain ?? I know racers do this, but is just weight loss or other benefits?
I bought a lightened clutch basket a while back at Wickstead, thought I would check the weight savings... (I cant remember the make of it, but its claimed to be Italian) Its actually heavier than the original solid GP Italian one that I was taking off...
The MB ones are lighter and seem very well made, I cant remember how much lighter, but I never bought it for the weight saving, I bought it cus it was recommended by the makers of the Foxhat spider that I was fitting, as the basket is deeper so lets the plates free off a little more than a standard sprocket would...
If your after engine response from light weight internals the flywheel probably gives a better option for weight saving... Any sprinters would machine the weight off anything that spins even the kick teeth removed off the first gear as any weight advantage is a plus, but the rotating parts even more of a plus...
- drunkmunkey6969
- Moderator
- Contact:
I know the MB ones are 'banded' and obviously s**t-hot quality....but never weighed one so dont know what they come up as....but these other 'lightened' ones (usually 5-plate affairs) are as you say usually much heavier than original italian 4 plate jobbys.
It because of the thickness of the metal plate on the base...sure the 'lightened' 5-platers have cut-outs...but the metal is loads thicker.
For my racer, i took an old italian one with the thinner base (already lighter than most) and made swiss cheese out of it with a drill, i then used a porting tool to cut out the deeper seats for the clutch plates for my FOXHAT 6 plate set-up.
CPH Lambretta
- registered user
- Main scooter: DL 150 1970
- Contact:
I was just having a look on the Scooter Center website and they list the weight of everything they sell.
Here are the weights of the Rear Sprockets they sell:
MBD 564 grams
Tino Sacchi 870 Grams
Sil 770 Grams
So the light weight Tino Sprocket weighs 100 Grams more than the standard Sil one
MBD 564 grams
Sil 770 Grams
Slow is the new fast!
