lammy front wheel
bawjaws
anyone got a diagram of a gp front wheel assembly (the spacer/nut setup really) reason i ask is because i changed the speedo drives on a gp and they arent even touching eachother, a wee gap between the brake drum and the hub, what size spacer between the hub and and brake?, thanks in advance....
Daggs
Take a look on Scooter Restorations site. They have exploded drawings there.
dapper
Look here as the guy has posted good photos
http://scooterotica.org/tempforum/viewt ... =17&t=4978
rog60
Main scooter: Indian GP200
bawjaws wrote:anyone got a diagram of a gp front wheel assembly (the spacer/nut setup really) reason i ask is because i changed the speedo drives on a gp and they arent even touching eachother, a wee gap between the brake drum and the hub, what size spacer between the hub and and brake?, thanks in advance....
Check you put the internal drive (on the stub) the right way round. i.e. nylon drive at the end of the stub.
bawjaws
cheers lads, turns out it was the wrong spacers, had to cut a couple of new ones doon, works a treat noo! :)
    Users browsing this forum: Baidu [Spider] and 2 guests
