Ideas for things to make
Supereibar
J1MS wrote:
Supereibar wrote:Ok David, see what you think. I only lack one suitable drift for my engine rebuilds. Maybe you can suggest one or maybe you could make one :?: :?: . It is the drift for bearing 6004. The Gearcluster bearing that goes on the endplate. I have to drift that using a socket, which is quite a bitch. Do you think you could make an iron drift?
All the best,
Jaime
This would be a good tool... Make one that works for putting it back in as well and I will buy one off you... At the moment I do as Supereibar says and use a socket to remove the bearing then press a new one in using a vice with a block of wood and an old bearing ground down (outer track) to push it back in... A tool that could extract and re fit the bearing would be good... 8-)
Hmmmm... I use a drift as well to fit it in. Why the complication of a vice and a block of wood? Just Hit the bearing on the outer track and you are on the safe side...
J1MS
Supereibar wrote:
All the best,
Jaime
Why not?? As I have a vice and a very nice block of wood, and as I never got around to welding a handle (To hit) to the modified bearing track the vice seemed a good idea, and it goes in all squared up in seconds...
Supereibar
is it like the tool i made that i've shown?
J1MS
Yes, wooden block with a cut out vice and ground down bearing track... Was thinking of using two tube sizes and a bolt with washers but never got round to making it, no longer have access to a machine shop, so now I am stuck with the wood and the vice...
Nic
mark wrote:how about a front brake lever pivot bolt that has a 8mm hole in top to take a tomtom fitting
Ooh, like that one! What about a Garmin Zumo as well??
martinr
theres a bit of lathe work i need doing if your interested david. its to do with a rear disc setup. ive got a ally boss that the disc fits onto and on the back of the boss theres a 2mm raised ring .what i need doing is a 2mm groove cutting into a rear hub to match the boss so it all runs true . i thought the way to do would be to bolt the hub to a layshaft and put the layshaft in the lathe and hope it spins true ish
cheers martin.
davidblythe
little drift to knock out the 6305 bearing from scrap bit of metal
rod locates into a 13mm hole 15mm deep on side you cant see
drift sits on inner track of bearing, doesnt interfer with the case
will do same for 6004 bearing and use same rod
soullad
martinr wrote:theres a bit of lathe work i need doing if your interested david. its to do with a rear disc setup. ive got a ally boss that the disc fits onto and on the back of the boss theres a 2mm raised ring .what i need doing is a 2mm groove cutting into a rear hub to match the boss so it all runs true . i thought the way to do would be to bolt the hub to a layshaft and put the layshaft in the lathe and hope it spins true ish
cheers martin.
Mates rear disk hub completely snapped off on way to Wicksteed parts fair last weekend. He had his Mrs pillion and riding along normally when suddenly he heard an almighty crack. The disk centre was still left insitu but the remainder of the hub / rim was wedged up inside the frame. Luckily it dumped them onto the verge but badly shaken n bruised.
Think carefully before you make any modifications, thats all...........
    Users browsing this forum: Google Adsense [Bot], Semrush [Bot] and 3 guests
