Removing bearing collar
Bufficus
What methods are we using for removing the bearing collar from cranks Gents?
J1MS
Bearing puller bought off Adam Winstone few years back now...
But before that a bearing track puller available from Machine Mart, but for this the crank needs to be out of the engine...
I generally carefully cut a slot with an angle grinder and knock it off sharply with a chisel.
The best way I have seen is by CSE. Chris has made a tool like pliers with a ring coller. Heat this end then quickly grab the collar, the heat transfers to the collar and it just slips off. Uses the same in reverse to fit a new one.
Captain Chaos
I've seen that at CS Jarv
It's a brilliant bit of kit isn't it? Simple, but very effective.
I use the grind/tap off technique, but the CS tool is definitely a great way to do this job.
monkey boy
Hi
Any idea if these tools can be bought??
AL
ring him he probaly make you one
Bufficus
Thanks fellas. I'll have a go at the grind/tap method I think.
lambro63
Main scooter: series 2 TS1
any contact numbers for this type of tool,,,,,,, any photos etc
regards
big pete lambro63 (spiderman)
westburyst
hello,
i've gone for the grind and tap method as I do not have access to any of the tools for easy removal. but the tap ain't happening, collar is real stubborn. how hard? i do not want to hit it too hard as i do not want to cause any damage.
cheers
SIL GP200 92'
I've lost count how much I've spent.
kettle stream and mole grips
    Users browsing this forum: Google [Bot] and 42 guests
