atomiser and needle help
leigh
its a 34 delly, having changed exhaust from nk to franspeed runs rich in mid range, at mo have a dp266 miser and k21 needle even on its leanest setting runs rich whats my next atomiser/ needle options. pretty sure the needle is lowest option for this atomiser
cheers in advance
leigh
EID
Had same problem,changed to a DQ266 as advised and it seems to have done the trick.
leigh
what needle did you use mate
EID
I kept the same needle [K21]and just started with the clip in the bottom position.then dropped the needle to suit.
jonny snatchsniffer
that the needle is the leanest one he can get but with his atomiser it runs rich
