Trick for recovering speedo cable nut?
If you have a compressor/air line you can blow it back up from the bottom end.
Supereibar
drunkmunkey6969 wrote:If you have a compressor/air line you can blow it back up from the bottom end.
Does it come out like a flying saucer?
sydduckett
garden cane and little uns playdo works every time first time....... ;)
blob of grease on bit at top of cable outer then pull cable down inside fork stem to bottom then feed cable back up with thread attached . seemples
sideout
You'll have someone's eye out with that! ........ :lol: :lol: :lol:
