phbh28mm
Tosh
please does anybody no if this carb is ok to use for a 200 stage 4,its off a aprillia motorbike
got a price £30
Stokie
You'll need to block off the brass tube that sticks out where the carb fits into the rubber mount (I understand it's for oil injection) and you'll need to check the jets, slide and atomiser and swap as necessary.
The air screw and idle adjustment screw are on the opposite side to a carb that you'd buy from most dealers to fit to a Lambretta so the engine mount will be in the way making adjustment a little awkward (but not impossible).
Other than that it should work fine.
eibargum
Once sorted like Stokie suggest,s its a very good and comonly used carb on a Indian stage four, loads of people use them.
Tosh
thanks both of you for the replys will pick up tomor,would it be better with openend or through a foam fillter
eibargum
If you want it to last and keep it clean then a Ramair is a good idea, but you,ll get a bit more power open mouth,d IMO.
Knowledge
Tosh,
Not all Aprilia 28mm carbs are not suitable for piston ported two-stokes. Many do not have the primary choke around the needle. You need to check.
Open the slide and look down the mouth of the carb. As the needle descends into the hole in the bottom of the venturi, there should be a small brass collar around the hole. It is about 4-5mm high. If it isn't there, you will have problems with over-rich carburation at low revs unless you have a reed valve.
The carb can be altered to the correct spec, but as well as changing the collar, you will need new atomisers. The primary choke is about £9, the new atomisers are £9 (both plus postage) and someone to fit it (ME!)
Sorry. It's a bit of a bummer.
(I've got a 28mm PHBH two-stroke carb for sale, which I will have with me at Wicksteed)
Martin
Tosh
thanks Knowledge 4 that someone in our club as a PWK30 new thought about trying that
    Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 19 guests
